no response from pic18 dev kit USB port
Discussion in 'Embedded Systems and Microcontrollers' started by gongon, Aug 15, 2011.
  1. gongon
    Aug 10, 2011
    i m using mplab 8.73a to work with the pic dev kit. everything goes alright but there is no response from the usb port.
    when i plug the usb to my pc, no response, nothing pop up in my pc, my pc cant detect the device and the mplab shows ICD0019 error.
    i installed the usb driver already. my pc just cant detect the device. what can i do?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I do not know what kit you have. Can you tell us? Perhaps it has some settings that enables you to select using external power or USB. If it is set to external power it may not use power from the USB. And with no power it will be "dead"
