No power
Discussion in 'The Projects Forum' started by gpad, Jan 27, 2007.
  1. gpad
    Jan 27, 2007
    Currently I am working on a septic tank aerator motor.Motor has been rebuilt so i know it ok.I also replaced the power relay and fuse to the timer. the motor has 2 sets of 3 wires and a ground wire. I have wired it every way possible and still have no power.Open to suggestions.Thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Need some more information on the motor. And did you check at the motor with a meter to confirm no power?
  3. wireaddict
    Nov 1, 2006
    133
    Check inside the motor terminal box or "pothead" cover or name plate for a connection diagram. If there is none, I'd go back to the shop where it was rebuilt & ask them how to wire it up. I suspect it's getting power but it's hooked up wrong.
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Was gonna say something about Sh!t stirring, but I'll refrain.
    You may also want to get the shop to retest it as well, just to put your mind at ease, and to check that none of the smoke has been let out of it in the previous hook up attempts.
