No output from the enable pins....pls help
Discussion in 'Embedded Systems and Microcontrollers' started by nirmal_rockin, Sep 9, 2009.
  1. nirmal_rockin
    Aug 7, 2009
    hi this is the schematic for my line follower.. the problem is tat i don get any output from both the enable pins(pins 18 and 19 of the mc). due to wch the motor refuses to. run... nw i'm confused how to resolve this problem...
    any one help pls...
    i hav also attached the source code for the mc...
  2. mik3
    Feb 4, 2008
    Take care of the fuses which define the function of the pins (OC1A and ICP) and if you have configured the pins as outputs.
