No. of Comparators in a Flash ADC.
Discussion in 'Homework Help' started by Denny1234, Mar 7, 2009.
  1. Denny1234
    Feb 17, 2008
    27
    Hi, im researching flash ADC's for school presentation, via this website's link on the subject - however the following statement confuses me...
    "Unfortunately, it is the most component-intensive for any given number of output bits. This three-bit flash ADC requires eight comparators. A four-bit version would require 16 comparators. With each additional output bit, the number of required comparators doubles. Considering that eight bits is generally considered the minimum necessary for any practical ADC (256 comparators needed!), the flash methodology quickly shows its weakness. "
    http://www.allaboutcircuits.com/vol_4/chpt_13/4.html
    I thought that 2n-1 comparators were needed, so shouldnt a 4 bit require 15 comparators (not 16) and a 8 bit - 255 comparators? - and a 3 bit should require 7?
    Thanks for any help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You are correct.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ron, I have responded to your post in the Feedback and Suggestions forum.
  6. Denny1234
    Feb 17, 2008
    27
    Thanks for your help.
    Just could I ask about one thing I cant quite understand?
    The following statement..
    Comparators -
    "They are designed for low voltage offset, such that the input offset of each comparator is smaller than a LSB of the ADC. Otherwise, the comparator's offset could falsely trip the comparator, resulting in a digital output code not representative of a thermometer code
    When it says smaller than a LSB of the ADC - is that refering to the voltage formed by each potential divider (of the analouge imput Voltage) that is to be 'compared' to Vref?
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Yes, the voltage represented by an LSB change is equal the the voltage across any single resistor in the reference divider chain, providing that all resistors are of equal value.
    Note that Vref is applied to the divider chain, not Vin.
