No matter how much I measure before hand......
Discussion in 'General Electronics Chat' started by jerseyguy1996, Jul 9, 2011.
  1. jerseyguy1996
    Thread Starter Active Member
    Feb 2, 2008
    206
    9
    This always happens......
    Just wanted to vent....
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just squeeze that 1N5821 in a vice a bit...
    That reminds me... I once saw that someone had tuned the value of a resistor by using a Dremel moto tool (or similar) and a small rotary sanding drum to take a "U"-shaped section out of the side of it...
  3. davis.jacobj
    Jul 7, 2011
    5
    Do you use pcb layout software? Makes it so that doesnt happen. :)
    If you dont, get EAGLE. Www.cadsoft.de. Relatively low learning curve, i think.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I once used a Dremel to change a 1N5821 to a 5082-2835.;):D
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
    I think that only works with carbon composition resistors. It's been a long time....
  6. #12
    Nov 30, 2010
    16,704
    7,352
    LOL! Practice, practice, practice. You'll get better or learn to let the fat ones live half an inch off the board. ;)
  7. debjit625
    Apr 17, 2010
    790
    186
    I know how it feels,just bad luck...
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Actually, we've done that to increase the resistance of chromium coated tungsten rods used for vacuum deposition. Shaved the diameter to half over the length of the rod with a diamond burr. ;)
    Ken
  9. Markd77
    Sep 7, 2009
    2,803
    594
    Definitely not going to work with wire wound resistors...
  10. ErnieM
    Apr 24, 2011
    7,439
    1,627
    @jerseyguy: can you use a SMD diode on the back side? It might look a little cleaner if you can get a large enough package to span the thru holes.
    Wish I could say I'm immune to these things too. Just last week I found I had miswired a SOT-23 AGAIN! I seem to have a particular brand of mental defect I refer to as "transistor dyslexia," the complete inability to understand the simple spacial relationships between base, emitter and collector.
    In this case, I was laying out a previous working PCB design to a new form factor, same parts, different board shape. I "improved" the SOT footprint to the "standard" pin 1 2 & 3 configuration without checking my schematic symbol which was laid out to some random configuration, so the auto router and design rule checks thought all was fine. And since I had already made "this" board I shorted my manual checks.
    Fortunately I could spin the device and still get proper connectivity to ship my prototype.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have a set of templates I call PaintCAD. I try to draw the components as close to real size as possible, Someone mentioned the PCB software, the same thing applies. I use Express PCB, but in this the exact software doesn't matter a lot, the feature is in all of them.
    Experience helps, but this is definitely a case of measure twice and cut once.
    Look at it this way, it fit. :D
  12. jerseyguy1996
    Feb 2, 2008
    206
    9
    I just shoved it in as far as it would go and soldered it on. I decided in the end that I didn't really care if it looked pretty or not.;)
  13. jerseyguy1996
    Feb 2, 2008
    206
    9
    I use expressPCB as well and had to draw the terminal block from scratch. I guess I read the dimensions wrong on the datasheet. But like you said.....it fit....just not very well.
  14. ErnieM
    Apr 24, 2011
    7,439
    1,627
    I'm not familiar with Eagle, I use Orcad's PCB Editor (Allegro), which has a "place bound" property, basically a keep-out area for other place bound shapes. Keeps from putting a part on a part IF you make the footprint correctly.
    If.
    I would be surprised if Eagle didn't have a similar feature.
