I am a web developer with only very limited knowledge about electronics so I need some help/advice from someone please.
I need to build a small electronic device which can do the following things.
1. connect to a wifi network
2. each device should be able to be given a serial number
3. get the direction the device is pointing to
4. submit every second a request via the wifi network which will look like this:
5. has a pressure sensor (only on or off) if on an additional request is sent that looks like this:
6. has a on/off button
7. has 2nd button that if this is pressed another request is sent that looks like
8. is battery operated.
Now the device should be as small as possible. Ideally the size of a laserpointer.
Can anyone give me any advice??
Thanks alot.
Rich (BB code):
http://10.115.0.243/recordData.php?serial=ydhkdjd&direction=90
Rich (BB code):
http://10.115.0.243/recordData.php?serial=ydhkdjd&direction=90&pressure=on
Rich (BB code):
http://10.115.0.243/recordData.php?serial=ydhkdjd&direction=90&end=true
Thanks alot.
