Hi all,
I would like to run my radio shack from 12Volts PS - constant & no break is what I desire. In my hot little hands I have a huge truck battery(12V) and also a GME PSE1225A, regulated at 13.8V.
so is there is a way to 'reasonably' use the 13.8Vdc PSU in parallel.? I'd ideally like the PSU to trickle charge the Battery and as soon as mains drops off the battery runs the show. This device, the EBS-1 looks ideal in the way it works.. what would be inside it I wonder?
my real concern is the battery... and I going to kill it? sulphation? is the 13.8Vdc not high enough - Gassing voltage is about 14V.. does I need to get it gassing? if mains falls low.. would the battery feed back into the PSU ?
appreciate all input.. battery charging to me is a bit of a black magic..
Thanks!
Thanks!
