nmos current mirror with differential pair
Discussion in 'General Electronics Chat' started by leo47, Jun 5, 2006.
  1. leo47
    Jun 5, 2006
    Why is it better to use a differential pair to guide the current to the output node, rather then using just one simple switch?
    Anyone an idea?
    I made a current steering dac and somebody asked me that question but I just took the diff. pair because everbody uses it, i don't know why it is better.
  2. Ron H
    Apr 14, 2005
    7,050
    655
    If you really use complementary switching signals for V1 and V2, you can use lower peak-to peak input signal swings, the voltage across the current source M3-M4 doesn't change (yielding temperature stability and faster output settling), you will get outputs that are "complementary", and there will be minimal (zero, ideally) change in IDD, which keeps supply noise to a minimum.
    In the Electro-Tech forum, I missed your statement that this was in a current-steering DAC. Sorry about that.
