Nixie Kit N00b
Discussion in 'General Electronics Chat' started by scythis, Oct 28, 2010.
  1. scythis
    Oct 28, 2010
    Hi y'all
    I am buying a Nixie clock kit and could probably buy the parts myself but I am a true beginner and really just want to assemble the thing lol.
    Here's the Nixie clock with a PCB board. My old soldering iron fried on me and I need a new one anyways. From their instruction manual:
    • Do not use solder with acid, instead use colophony or any other not electrical conductive solder resin.
    • Set the soldering iron at appropriate temperature to avoid “cold soldering”.
    • Do not heat any point for more than 3 seconds
    What soldering iron and accessories are best for PCB soldering and do I need any other special tools for this?
    Thanks in Advance!
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Look into a Weller WLC100 - last iron you'll ever have to buy.
    As to solder, any good electronics solder around 0.031" diameter is fine.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Further on the solder - Kester#44 63/37 eutectic is as good as it gets. Lead free solder is miserable stuff to work with. With tin/lea solder, you can see a good joint easily. The deposited solder will be shiny and will have flowed nicely onto the PCB pad and the component lead.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  5. scythis
    Oct 28, 2010
    Solid Gold Advice and then some - thanks much
