Nintendo DS Lite Circuit Board/SMD Identification HELP
Discussion in 'General Electronics Chat' started by VivicElectronics, Mar 1, 2012.
  1. VivicElectronics
    Mar 1, 2012
    I have a Nintendo DS lite with a component that is definitely cracked and or damaged.
    The part looks to be called EM10 and is located just below the charging port, which I'm guessing will explain why the ds will not charge. If i can get some help identifying this so I can replace it It would be very much appreciated
  2. Tealc
    Member
    Jun 30, 2011
    140
    10
    Bit tricky without a picture.
  3. VivicElectronics
    Mar 1, 2012
  4. VivicElectronics
    Mar 1, 2012
    Just click the link
  5. BSomer
    Member
    Dec 28, 2011
    433
    106
    The device that you pointed to in your picture could be a capacitor or an inductor. It is kind of hard to tell for certain though. If you have a multimeter on hand, check to see if you have continuity through the device labeled "F1" which could be a fuse.
  6. jrm
    Member
    Oct 11, 2011
    38
  7. Sparky49
    Jul 16, 2011
    835
    417
    Good find!
  8. VivicElectronics
    Mar 1, 2012
    Thank You so much for your assistance that is the part exactly! and thank you for your assistance as well bsomer, I did check that continuity and it is there. The EM10 had a crack in it and no continuity so that is my next thing to replace. Thank you so much again for the link jrm :)
