nidec BLDC motor
Discussion in 'General Electronics Chat' started by mah, Dec 22, 2015.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i have BLDC motor from nidec extracted from panasonic printer but i don't know how to run it. i connect 24 V and ground terminals but nothing happened .Does it need PWM input ? the motor has 8 pins , what is the least number of pins to run it?. if any one helped i would be grateful
  2. shortbus
    Sep 30, 2009
    4,098
    1,697
    All BLDC motors need a driver. The driver takes the place of the normal DC motor brushes.
  3. mah
    Mar 15, 2010
    276
    I think that the electronic circuit in the pic is the driver, Isn't it ?
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Are you sure it is BLDC?
    The wire label for the 8 conductors does not indicate this?
    For BLDC you would normally have:
    3 for the stator windings, 3 for the hall effect or commutation and 2 cond. for power.
    Max.
  5. mah
    Mar 15, 2010
    276
    actually i am not sure that it is BLDC motor but there is a video youtube have the same BLDC motor .
    but i want to know should i need all pins as in the picture they are , 24V,24v,PGND,PGND,LD,start/stop,clk,brake. whare those pins and which will i need to run it?
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    The Utube video pretty much explains the connections and confirms it is a BLDC motor so it must have an on board controller.
    The demos shows all the connections.
    Looks like he made a speed controller circuit.
    Max.
  7. mah
    Mar 15, 2010
    276
    yes he used speed controller but the connection isn't clear, if you see it please explain.
