NiCr heater
Discussion in 'The Projects Forum' started by Bluespark, Oct 21, 2013.
  1. Bluespark
    Oct 21, 2013
    hi,
    i am currently building a vac-former and i would like to a NiCr heater to heat the plastic. i need to be able to control the tempter and would like to split it in to three zones. the area for the heater is 2ft by 3ft. so a zone would be 2ft by 1ft.
    would love some help,
    thanks,
    Bluespark
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Do u want strict temp control over ur desired range ?
    Bluespark likes this.
  3. Bluespark
    Oct 21, 2013
    it would be best to have a strict control as the tempter is need is affected by thickness and the type of plastic.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
  5. Bluespark
    Oct 21, 2013
    i was thinking of using three tempter gauges mounted under the heater. what would you recommend to use.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    Damn..those are dirt cheap.
    Gotta love Chinese labor rates ;) ...well unless you are enslaved there anyways..
  8. wayneh
    Sep 9, 2010
    12,394
    3,246
    And yet, we have to borrow money from them to keep buying votes. Who's enslaved to who?
  9. Bluespark
    Oct 21, 2013
    thanks, were would you recommend buying the NiCr wire from i have looked around but there all different so which would you recommend as well. Also how would you recommended setting out the wire?
    First time i have used NiCr wire as a heater.
    First time is always the hardest.
