I am replacing a 110 volt 800 watt heating plate attached the bottom of a lab water bath. i have chosen to use two 400 watt nichrome coil elements controlled by the bath's three position analog rheostat heat the bath to 100 degrees F.
Question:
Is it feasible to use 1/8 inch thick HDPE sheets as insulation to enclose or other wise sandwich the nichrome heating coils, without reaching the melting temperature of HDPE (248 degrees F.)?
Question:
