I'm not sure what is the cut off voltage before the remote stops working. I might be able to test that out with a variable DC supply.As for voltage drop how low does your battery voltage go before the unit stops transmitting?
At a ~15 ma draw when transmitting the 2200 uf capacitor should easily give you several seconds of transmit time before its charge voltage drops too low. If not then the resistor could be reduced to a 100 - 200 ohm unit and a larger capacitor could be put in.
If I recall correctly, the typical (average) transmit current is 7mA and the peak is 15 mA. Assuming I use 7mA and a 500 ohm resistor, the voltage drop across the resistor is 3.5V. That would leave me with 9.1V across the capacitor if the source battery is at 12.6V. Is this correct?
By the way, what is the capacitor for?
What could be the side effects if I don't use a capacitor?
Thanks again.
