NiCd Battery charger
Discussion in 'The Projects Forum' started by SahAn, Jan 23, 2016.
  1. SahAn
    Jan 23, 2016
    6
    Hello guys,
    I am a beginner in electronics.
    I have a new 12V,1.5 mah NiCd battery, and 12V 2A adapter.I want to make a battery charger for the same. How to make one?
    I am going to use it on my line follower bot.
    Moderators note: taken the essential parts from the pictures, we do not need the tablecloth.
  2. Dodgydave
    Jun 22, 2012
    5,166
    776
  3. crutschow
    Mar 14, 2008
    13,511
    3,385
    Yes, you need more than 12V to charge a 12V NiCd battery.
  4. SahAn
    Jan 23, 2016
    6
    Thanks for reply!!!
    Using 12V, will allow me to charge battery upto 12V right? Won't it help With respect to overcharging? Or will it create any problems
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    Possibly
    Measure the power supply voltage with no load on it and again with a load of about 1/2 amp.
  6. SahAn
    Jan 23, 2016
    6
    what you think about this circuit??
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Without any values given, it is impossible to say.
    Bertus
    PS I reduced your pictures to their essentials.
  8. SahAn
    Jan 23, 2016
    6
  9. SahAn
    Jan 23, 2016
    6
    R1 - 1.2 kilo ohms 1/4W
    R2 - see R2 and D2 table below
    R3 - 2 kilo ohms 1/4W
    Q1 - TIP41C or any NPN transistor min 1A current and 3W power
    Q2 - 2N2222, CS9013, or similar NPN transistor
    LED1 - Red or any LED with forward voltage around 2V (see LED)
    LED2 - yellow or any LED color except Red
    D1 - 1N4001 or similar diode
    D2 - see R2 and D2 table below
    DC supply - 12V to 15V DC supply or battery
    Read more at http://www.simple-electronics.com/2011/10/simple-ni-cd-charger-automatic.html#seBZzFtOBHcCE1C6.99
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Led 1 is important for the charging current.
    Led 2 will show the end of charge, it will reduce the charge current.
    The voltage table does not show a value for an 12 volts battery zener value.
    Bertus
  11. SahAn
    Jan 23, 2016
    6
    The imp thing is to save battery from damage. That zener value is max voltage battery can handle. For 12V, 12.56 to 13V
