(NiCD bat device) - What TM Resistor? Polarities?
Discussion in 'The Projects Forum' started by JoeyElectronicsGuy, Feb 5, 2016.
Thread Status:
Not open for further replies.
  1. JoeyElectronicsGuy
    Feb 5, 2016
    6
    Mod edit: snipped links and images of Transformerless PSU
    Hi all,
    I'm trying to build this NiCd device to fix my batteries:
    But I have a couple questions (b/c the diagram is hard to see):
    What is the size of the TM (TradeMark) resister, 47K. 2000k, 5000K 0r what size is it 1/4 or 1 or 2 Watt resister. Need to know. If the resister is to small or to large the NiCd Battery Reconditioning Device will not work and could burnout the resister.
    Also, looking at the diagram to build the NiCad fixing Device I can not determine the polarity for the capacitors in the wiring example. The instructions stress getting the polarity correct. Could someone please let me know the correct wiring polarity?
    Also the K value for the TM Resistors is not provided. Do you have a guess at what this info is?
    And what K value and wattage for the TM resister do I need? Could you provide a link for this resistor as was done for the 47 K resistor?
    Thank you so much. Any advice you can provide would be very helpful. If you have any specific TM or 47 resistors you recommend that'd be helpful too.
    -Joey
  2. Dodgydave
    Jun 22, 2012
    5,144
    769
    You won't get far with this project, its forbidden here, its a transformerless psu.
  3. JoeyElectronicsGuy
    Feb 5, 2016
    6
    Hmm. Shoot. Well do you happen to have any recommendations? I really want to build this.
  4. Dodgydave
    Jun 22, 2012
    5,144
    769
    47K and 1M resistors are used, use 1/2W ,you can do the same job with a transformer dropping it to 60v.
  5. ronv
    Nov 12, 2008
    3,393
    1,454
    It's probably just as well. The short in the battery quickly grows back.
  6. JoeyElectronicsGuy
    Feb 5, 2016
    6
    --> Okay, thank you. So I'll use a 47k and 1M resistor.
    Do you think this will be a good 1M (1/2) W resistor: https://www.radioshack.com/products...-carbon-film-resistor-pk-5?variant=5717284613 ?
    And are you able to determine the polarity for the capacitors in the wiring example?
    Lastly, do you know what the K values should be for the 1M and 47K resistors?
    Thank you so much. I appreciate your help very much.
  7. JoeyElectronicsGuy
    Feb 5, 2016
    6
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    The owners of All About Circuits has elected not to host discussions of transformerless threads.
    Transformerless powersupplies are not allowed over here.
    See point 6 of the user agreement:
    http://www.allaboutcircuits.com/user-agreement/
    If you wish to change to using the transformer to discuss then please press report, when our mods through the discussion if we decide to reopen it then we will reopen.
    Good luck.
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I have banned the user for 3 days, as he brought up the same circuit for the third time.
    Wendy and I have warned him about this.
    Bertus
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    I already made that very clear, if he won't listen, ban him is the good choice.
Thread Status:
