Hi, i wanted to use the attached circuit as an intelligent NiCad battery charger. However, i am contemplating changing the NiCad battery to a sealed lead acid (SLA), because my research indicates that they are more suitable for float charging. The battery is to be used as a backup power supply, so it will constantly be within the circuit.
My question is can i modify the circuit to work for an SLA battery. As far as i understand, would be altering the constant current source to a constant voltage source be sufficient?
What else would i need to take into consideration?
