NiCad Restorer Question
Status
Not open for further replies.
JoeyElectronicsGuy
Joined Feb 5, 2016
6
Mod edit: snipped image of Transformerless PSU
Hi all, I'm trying to build this and was wondering two questions:
1) Which way does the positive end of the 2 capacitors face in the Diagram? Towards the alligator clips or towards the AC line cord. Physically. They are not marked.
2) Also, do you think the push button switch momentary or not?
3) The neon light doesnt work in the test one I'm building. But I have a 105v to 125 v ac/dc lamp. Maybe I should have bought one with a lower voltage rating. What do you think?
4) What should the output at the alligator clips be?
5) I have the diode but was wondering about the polarity of the caps. Does it make a difference which way they are connected?
Thank you. Any help with any of the questions above would be very much appreciated.
ian field
Joined Oct 27, 2012
6,536
The best way to revive Ni-Cd cells is with pulses.
One of my designs was a modified ATX PSU, a charge coupled voltage double which is inherently current limiting was fed from a secondary on the chopper transformer.
The rectifiers were deliberately mis-matched - the shunt diode in the doubler was Shottky-barrier to minimise negative pulse amplitude, the pass rectifier was just a fast recovery silicon type so the reverse recovery spike caused a very narrow charge current reversal.
My charger was used exclusively for 4.8V packs, so the current draw from the 5V rail that's needed to keep the PSU running, provided a steady charge bias through a current limiting resistor.
More recently I've had a project published in Elektor magazine. Its a basic linear PSU design, but a zero crossing detector pulses a MOSFET to shunt the battery between rectified half cycles. The magic is in the blocking diodes that prevent the battery voltage interfering with the zero crossing detector, and preventing MOSFET activation in a power outage.
Not recommended for Ni-Mh, except for short treatment sessions on cells that have got lazy.
ScottWang
Joined Aug 23, 2012
7,400
The owners of All About Circuits has elected not to host discussions of transformerless threads.
Transformerless powersupplies are not allowed over here.
See point 6 of the user agreement:
http://www.allaboutcircuits.com/user-agreement/
If you wish to change to using the transformer and continuing to discuss then please press report button, when our mods through the discussion, if we decide to reopen it then we will reopen.
Good luck.
Status
