Hello,I have received some relay/fuse panel diagrams for my car. . There is a 10 amp fuse for brake lights which looks good,but I will replace. Next, there is a stop lamp inhibit relay(which is energized when brake light switch is activated by foot pedal). I have already replaced this relay-brake lights including center lamp still dont illuminate. It may be then, that changing the brake light switch under foot pedal- is the best next thing to change. What do you think? Thank you in advance!
