Next step after proof of concept solderless breadboard?
Discussion in 'The Projects Forum' started by elRey, Sep 15, 2009.
  1. elRey
    Thread Starter Active Member
    Feb 23, 2009
    65
    New to electronics and I just completed a proof of concept (with much help from these forums) on a soderless breadboard. I want to test it on the car and don't think breadboard would survive the ride.
    What's the next step? Thanks,
    Rey
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What kind of circuit? Where is it going?
    You could build a solder type version, that is the norm.
  3. elRey
    Feb 23, 2009
    65
    PWM with 556, 339 and 324 driving a LL MOSFET powered buy 11-14v thru a 7805. The circuit itself will be in the cabin with me. Any tutorial videos of sodered board assembly?
    Thanks,
    Rey
  4. elRey
    Feb 23, 2009
    65
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. elRey
    Feb 23, 2009
    65
  7. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Those clad perf boards are a hassle. Just get the cheap glass perf boards with no cladding. I use a 30 gauge hook up wire, various colors of insultation and do point to point soldering.
    heres an old 68020 system I patched up about 20 years ago. Surprised to find it in the bottom of a junk box;
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Personally I prefer the copper pads, they allow me to tack the parts down to the board itself, as well as the wires. It is a personal choice, either works well. The pads make it more secure, but also harder to modify.
    You can also get PCBs laid out as protoboard from Radio Shack and other source, if you want to stick with the lay out you've already done.
