News: negative capacitance discovered
Discussion in 'General Electronics Chat' started by vpoko, Feb 4, 2015.
  1. vpoko
    Jan 5, 2012
    258
    47
  2. joeyd999
    Jun 6, 2011
    2,756
    2,924
    Sounds like the capacitor equivalent of a gunn diode.
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Ahh, a flux capacitor. Just what I need for the time machine I built in 2081 :).
    #12, MachineHum and cmartinez like this.
  4. Reloadron
    Jan 15, 2015
    1,051
    275
    You too? I need one for my matter transfer device so I can beam my ex-wife into the center of a concrete and brick wall. :)
    Ron
  5. GopherT
    Nov 23, 2012
    6,308
    4,029
    Careful, alec_T could use his flux capacitor to blow you back to when she wasn't your ex-wife.
  6. Reloadron
    Jan 15, 2015
    1,051
    275
    Ya know, I never thought of that. Alec, get it working I need to go back to 1975, June of '75 would be cool. Thank you Gopher for pointing that out.
    Ron
  7. Alec_t
    Sep 17, 2013
    5,971
    1,135
    It is working, ...... in 2081. Unfortunately it won't have a reverse gear until 2317 :(.
  8. MachineHum
    Member
    Nov 3, 2014
    70
    Yes.
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    It sounds like the article isn't making a distinction between large-signal and small-signal behavior, but what they do describe would be consistent with an incremental negative capacitance riding on top of an overall large-signal positive capacitance. Depending on how much hysteresis the phenomenon exhibits, it could well have some interesting and useful properties.
  10. ErnieM
    Apr 24, 2011
    7,436
    1,626
    I started on a time machine once. It was going very well until I was startled to see I had tapped myself on the shoulder and told myself "this will not end well."
    Nuff for me. No more playing around with the time continium.
  11. joeyd999
    Jun 6, 2011
    2,756
    2,924
    You could've at least given yourself a stock or Superbowl tip.
    Or, at a minimum, "Whatever you do, don't marry that girl!"
  12. GopherT
    Nov 23, 2012
    6,308
    4,029
    Everything else was survivable or reversible except further work on the time machine. Therefore, I think the most critical message was passed through the continuum.
  13. joeyd999
    Jun 6, 2011
    2,756
    2,924
    That would be "discontinuum", no?
    GopherT likes this.
  14. #12
    Nov 30, 2010
    16,679
    7,321
    I can't imagine how to make this useful, but those eggheads will probably find a dozen applications in a month.
  15. GopherT
    Nov 23, 2012
    6,308
    4,029
    You are right in your literal phrase but wrong in the way I perceive what you said. The way I read your comment "...those eggheads will probably find a dozen applications in month" implies that those are real and useful applications. I think they will ride out their careers writing papers, writing research proposals and promoting their discovery. I doubt we will ever see any useful implementation of negative capacitance.
    By the way, if capacitance causes voltage to trail current, would negative capacitance cause the reverse? Oh, wait, that is just inductance. So, what is negative capacitance exactly?
    Kidding aside, it appears to me that they found a way to measure the capacitance while a crystal phase transition occurs - rapidly changing the charge density. Phase (or crystal lattice) commonly changes with temperature (e.g. iron at 910 C). Rapid light pulse has shown change - I don't have a reference handy. I would not be surprised if a rapid electrical pulse can do the same.
  16. WBahn
    Mar 31, 2012
    18,085
    4,917
    My guess is that it's a voltage-induced phase transformation.
    Just as the negative resistance region of tunnel diodes have useful applications, I suspect that the negative capacitance region of these materials will have useful applications.
  17. nsaspook
    Aug 27, 2009
    3,011
    2,357
    They might as advanced Meta-Materials.
    http://www.e3s-center.org/pubs/106/PEB2012_7_DSievenpiper_Webfinal.pdf
  18. Alec_t
    Sep 17, 2013
    5,971
    1,135
    It will make a brilliant high voltage generator (if you believe Spice!) ;). Check this sim of the cap charging from a 1V supply :-
  19. WBahn
    Mar 31, 2012
    18,085
    4,917
    The problem with the sim is that it is modeling the large-signal capacitance as being negative. That's not the case -- it's the small signal capacitance over a limited operating region that is negative.
    Just as with the negative resistance region of a tunnel diode, if the large-signal resistance was negative then the diode would be producing power, but because it's the incremental resistance that is negative you don't have that.
  20. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Sorry, I forgot the [joke][/joke] tags ;)
