Newbie
Discussion in 'The Projects Forum' started by ricker24, Mar 5, 2011.
  1. ricker24
    Mar 5, 2011
    53
    Hello, I am new to the site and fairly new to electronics but am very interested in learning. Right now I am looking for someone to point me to a thread that has a circuit diagram of how to build a 2 digit scoreboard using either just led lights or 7 segment displays. Thanks for any replies.
  2. nerdegutta
    Dec 15, 2009
    2,568
    806
    Hi, and welcome!
    What are your budget?
    How big should the scoreboard be?
    Should it be one digit or multiple?
    Inside or outside?
  3. ricker24
    Mar 5, 2011
    53
    This will be used outside but only with dry weather. I would like to have 2 to 3 inch digits. I need 4 digits. I would like to basically just make it a 2 digit counter for each team(2 teams) that can be changed one number at a time and it will be scored from 1 to 21 with a reset switch. Budget is flexible but doesnt need to be extravagant. Thanks.
  4. nerdegutta
    Dec 15, 2009
    2,568
    806
    The least amount of LED I could think of is 92. See attachment. Then you need the power to run this... Have you googled 'big 7-segment' displays, or scoreboard. I could be wrong...
  5. ricker24
    Mar 5, 2011
    53
    Yes I have found some 3 inch 7 segments on Ebay. I have not been able to find a good diagram on how to build this with a reset switch and single digit segments.
  6. nerdegutta
    Dec 15, 2009
    2,568
    806
    Actually, I think you only need 84 LEDs.
    ricker24 likes this.
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    Make sure you test the LEDs or 7-segment displays you plan to use outside first in the appropriate lighting conditions. They might be hard to see.
