Newbie with transistor questions
Discussion in 'General Electronics Chat' started by wrenchbender, Jan 9, 2010.
  1. wrenchbender
    Jan 8, 2010
    8
    Interesting I found this forum by chance. I have the same 24v. batt. charger
    that a question was posted a couple months back. I used some of that info to troubleshoot my faulty system and eventually found a burned out transistor.
    I'm not sure where to purchase a replacement. It reads as follows:
    MCR 22-3
    M 047
    I'm a novice at this stuff, maybe you know a good website to order small quantities of components. All I seem to find on the web are large distributors.
    Also, how could I determine a sufficient replacement if this one is not available?
    thanks.
  2. VoodooMojo
    Nov 28, 2009
    503
    53
    that would be a Silicon Controlled Rectifier
    what part of the world are you so we can recommend a supplier
  3. spinnaker
    Oct 29, 2009
    5,062
    1,159
    An MCR 22-3 showas as a silicon controlled rectifier. Mouser and digikey don't seem to carry them. Perhaps someone can recommend a replacement.
  4. wrenchbender
    Jan 8, 2010
    8
    Thanks for the info gents.
  5. VoodooMojo
    Nov 28, 2009
    503
    53
    The MCR22-3 crosses over to:
    2N5062
    and
    NTE5402
    Jameco.com has them
  6. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I was wrong. Mouser has them but not the -3. I don't know how much difference it makes.
  7. VoodooMojo
    Nov 28, 2009
    503
    53
    this is the difference
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  9. wrenchbender
    Jan 8, 2010
    8
    A big thanks for all the help. I really appreciate the info. I will definitely be back to talk about guitar effects stomp boxes. I've been thinking about building some clones which would be fun, and allot cheaper than buying new.
    until next time... regards.
