Hello, this is my first post on these forums so I am not 100% sure if this is the right place to ask this question.
As a project for school, I need to design a cheap (under 80$) aquatic transport that can carry a 1-2lb object along the bottom of a shallow (2 ft) pool. It will be running for 20-30ish feet alongside a wall, and just needs to stay generally straight so it does not veer away from the wall into the middle of the pool. There will not be very much turbulence at all, and the faster it can travel the better.
My first idea was to just get a wide pvc pipe, slap a motor into the back, and cut out a hole to place the object in. But obviously it is more complicated than that, and I could use some help on the specifics (waterproofing a motor, how to keep it going straight, etc).
I have over two months to design it, but am trying to get a head start. Thanks in advance.
