Newbie trying to design a circuit for reactive archery target
Discussion in 'General Electronics Chat' started by LizaS, Jul 20, 2016.
  1. LizaS
    Jul 20, 2016
    Hi guys! I'm new to tinkering with electronics, but I would like to design a reactive archery target that consists of two foil plates, that connect when pierced with an arrow, closing a switch, causing a photography strobe to go off. Does anyone know where to start? I bought an arduino and a breadboard but haven't been successful in getting this thing to work yet.
    I would also like to add multiple targets for a round of shooting (without walking up to the circuit to reset the system).
    Any help would be much appreciated. Thank you!!
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Welcome to AAC!
    :confused: I'm unclear as to the purpose of triggering the strobe. The photo will show a static arrow, so could have been taken at any time without a strobe.
    What does the right-hand side of your pic show?
    What will the Arduino be used for?
    What do you mean by "reset the circuit"?
  3. Bernard
    Aug 7, 2008
    4,242
    418
    Parallel lines on right appear to be the foil switches. I do not see much success with this approach but piezo impulse detectors might work, worked well with paper target hit with rubber bands or b--b's from blow gun ( straw ).
    There is somewhere in Projects by dthx way back in May, 2013 a project for multiple" Bow & Arrow Target". The controller is still available.
  4. cmartinez
    Jan 17, 2007
    3,698
    2,794
    My approach would be to rather make an optical "curtain" right before the target that would be interrupted by the passing arrow. This would also allow you calibrate the moment at which you wish to take the photograph, by simply moving that curtain either closer to or away from the target. A piezo or mechanical switch would maybe be too late for the picture to be taken, since a delayed response by the camera is inevitable.
  5. EM Fields
    Member
    Jun 8, 2016
    252
    44
    When do you want the strobe to fire?
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    I agree with ALec. As described, the project doesn't sound very useful. What is it you are trying to achieve?
    ak
  7. LizaS
    Jul 20, 2016
    I'm not trying to take a photo, the flash is meant to be seen by the archer as an indication of a hit target (it gets hard to see if you hit the target when you start shooting from further than 40 yards). It doesn't matter when the strobe fires. Immediately to a few seconds.
    Looking at photography forums seems like a good idea, I will take a look.
    I can try a piezo impulse detector, is there a way to calibrate it to only fire above a certain threshold?
  8. Bernard
    Aug 7, 2008
    4,242
    418
    It's called a volume or amplitude control ie a pot. The sensor used for testing was a 20 mm piezo disc with a small weight ( dead LR41 battery ) glued to center of active side, piezo glued to thin plastic disc on which was also glued a small alligator clip. I think it fed into a 555 IC.
    Looked in old files & found Paper Target. It's start. Paper Target # 2 00000.jpg
  9. cmartinez
    Jan 17, 2007
    3,698
    2,794
    Can you post a picture of said target?
  10. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    These days, high brightness, narrow angle LEDs are common, low cost, and way easier to deal with than a photo strobe.
    ak
  11. EM Fields
    Member
    Jun 8, 2016
    252
    44
    Instead of a piezo impulse detector I'd use an electret microphone to capture the sound of the arrow hitting the target and a voltage comparator to trigger the strobe. The sensitivity of the system could be changed by adjusting the comparator's reference voltage and, if need be, by a filter after the microphone.
    Bernard and BR-549 like this.
  12. BR-549
    Sep 22, 2013
    2,184
    421
    I like it.
    A pffft detector.
  13. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    I think an acoustic sensor will generate more false positives than a contact sensor.
    ak
  14. EM Fields
    Member
    Jun 8, 2016
    252
    44
    Proper lensing should take care of that misgiving.
