Newbie to Microcontrollers- help with MCP4911
Discussion in 'The Projects Forum' started by stigmataZA, May 7, 2012.
  1. stigmataZA
    May 7, 2012
    Hi all
    i am as green as it gets with the microcontroller side of things. My field is in the PLC/SCADA game, however i am currently completing my studies and Microcontrollers is one of my subjects.
    I have what i am sure is a fairly simple question.
    i need to use the above chip in a design. I was considering using it for calibration purposes, ie, take a 0 - 10vdc regulate it then pass it through the MCP4911. the goal is to fine tune the signal which will allow you to calibrate the input, say a temperature chip that.
    the design is not the problem, it is the programming. i would like to use SPI between the MCP4911 and the PIC.
    the question i have is, has anyone used this chip in this configuration before, is this the correct application of the chip and does anyone have a sample code of the programming of the chip?
    any help would be great.
