Newbie Question: Understanding Ground
Discussion in 'General Electronics Chat' started by yosh, Jun 5, 2009.
  1. yosh
    Jun 5, 2009
    Hello all,
    First post! I'm new to electronics and self-taught. I'm mostly interested in musical and audio applications of this stuff for building synthesizers, audio effects, and other audio equipment.
    In many schematics that I have found, multiple parts of the circuit are connected to ground. In a portable, battery-operated unit, what should I connect these points to? The negative battery terminal?
    Thanks!!
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Yes. In a battery operated device the minus of the battery is the ground, if the device has single powersupply.
    If the device has dual powersupply the center connection between the plus and minus of the two batteries.
    Greetings,
    Bertus
    PS if you are interseted in making syntesizer stuff take a look at this website:
    http://www.musicfromouterspace.com/analogsynth.php?page=ANALOG
  3. David Bridgen
    Feb 10, 2005
    278
    Since you are new to electronics it might not be too late to prevent you from developing the habit of using the word "ground" in the cavalier manner which I so often see.
    Please read this http://www.davidbridgen.com/earth.htm
