Hello there, I programmed a code to divide my FPGA clock to my required frequency and then invert into two square wave, however I keep getting an error with the testbench stating "the module pulsegentb(file name) is instantiating itself".
And also with the file reports stating "the instantiation depth of pulsegatetb/notgate/notgate....is 51. This might indicate a recursive instantiation, increasing limit to 75".
Below is the code of the square wave generator and the test bench please can someone help me as to why I can't run the testbench?
Test Bench
module pulsegentb();
wire igbtclk1, igbtclk2;
reg clock, reset;
always begin
#1 clock =!clock;
end
initial begin
clock = 0;
reset = 0;
#10
$finish;
end
pulsegentb notgate(clock, igbtclock1, igbtclock2);
endmodule
Square wave generator
module igbt_clock_gen (clock,reset,igbtclock1,igbtclock2);
input clock,reset;
output reg igbtclock1, igbtclock2;
wire temp1;
freq_div f1 (clock,reset,temp1);
clock_multiplier c1 (temp1, igbtclock1,igbtclock2);
endmodule
module freq_div(clock,rst,clock_out);
input clock,rst;
output reg clock_out;
reg [15:0] counter;
always @(posedge clock or negedge rst)
begin
if(!rst)
begin
counter<=16'd0;
clock_out <= 1'b0;
end
else
if(counter==16'd6667)
begin
counter <= 16'd0;
clock_out <= ~clock_out;
end
else
begin
counter<=counter+1;
end
end
endmodule
module clock_multiplier (clock, clock1, clock2);
input clock;
output clock1, clock2;
assign clock1 = clock;
assign clock2 = ~clock1;
endmodule
Test Bench
reg clock, reset;
always begin
#1 clock =!clock;
end
initial begin
clock = 0;
reset = 0;
#10
$finish;
end
endmodule
input clock,reset;
wire temp1;
endmodule
input clock,rst;
reg [15:0] counter;
begin
if(!rst)
begin
counter<=16'd0;
clock_out <= 1'b0;
end
else
begin
counter <= 16'd0;
end
else
begin
counter<=counter+1;
end
end
endmodule
input clock;
endmodule
