Newbie Question: LED in parallel
Discussion in 'General Electronics Chat' started by Delita, Dec 28, 2009.
  1. Delita
    Dec 28, 2009
    Hi all!
    I recently became interested in building electronics, and I have a question about having an LED and a switch in parallel.
    I built the following circuit in a program called Yenka:
    My question is, since the LED is parallel with the switch, why doesn't current flow through the LED regardless of the state of the switch?
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  3. Delita
    Dec 28, 2009
    thanks for the response, and useful reference material =)
    however, the LED gets 0amps when the switch is pressed, and I'm still unsure why that is
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    When the switch is closed, all the current will go through the switch as its resistance is much lower as the leds resistance.
    When the switch is opened the current will flow through the led, if the led voltage is lower than the 3 Volts.
    The currrent will be (3 - Vled) / 100, in your case.
    If the led voltage is higher than 3 volts, hardly any current will flow through the led.
    Greetings,
    Bertus
  5. Delita
    Dec 28, 2009
    ahhh, of course!
    Thank you, I must not have been thinking straight =/
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've used voltage dividers to turn an LED off before, it used more wattage, but it was very similar to your concept. I explained it in this article I wrote a while back (and is still a WIP).
    LEDs, 555s, Flashers, and Light Chasers
