newbie question about circuit layout
Discussion in 'Homework Help' started by curry87, Jul 4, 2010.
  1. curry87
    May 30, 2010
    101
    If circuits a and b have the same current but b led has a vf of 9v will this be damaging to the led even though the current is limited ?
    How do i limit the current at 9 v supply dc to .1amp if i only have .250watt resistors what layout can i use to dissipate the power and limit the current without buying a 1 watt resistor?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Ohm's law is enough to let you determine the resistance. Use the form R = E/I, where you substitute in your voltage and the desired current. Power dissipation in the resistors comes from I^2*R.
