newbie problems with current source
Discussion in 'The Projects Forum' started by cgama, Dec 23, 2011.
  1. cgama
    Dec 23, 2011
    19
    Hi
    For my project I have designed this simple current source:
    So, I have my clocks going into the OpAmp to drive the LEDs.
    Everything is ok, I get a nice clock signal going out of the transistor but when I actually connect the probe with the LED (connecting to VCC), to me (a unexperienced person) it looks like im getting a lot of influence back from the VCC to the transistor collector output.
    in the oscilloscope, without the probe connected:
    Code ( (Unknown Language)):
    1.
    2. 3V     _     _     _     _
    3. 0    _/ \___/ \___/ \___/ \  (very rude graphics.....)
    4.
    5. with probe:
    6.
    7. 12V ----------------------
    8.          '      '      '             (it gives tiny dashes at the intendend frequency but that's about it)
    9.
    10.
    any suggestions?? thank you very much for your time!!
  2. cgama
    Dec 23, 2011
    19
    ohh the diagrams didnt come as intended.... sorry
    the idea is a clock signal for the first one varying from 0 to about 3V, and, for the second one, a constant signal at 12V with tiny dashes at the clock frequency
    thanks!!
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    The transistors NPN1 and NPN2 could function as current sources if loads (e.g.LEDs) were placed in their collectors.
    In this sort of application, it is important to remember that the voltage used to set the emitter voltage will subtract from the voltage span available for the load. Normally the emitter resistor voltage would not be very large, perhaps less than a volt.
  4. cgama
    Dec 23, 2011
    19
    ohh I see! so I get VCC minus the very low voltage from emitter, ence my 12V in the collector when I connect the load. right?
    This was adapted from another diagram, used for the same purpose, and the other diagram is working fine... (the other had 3 LEDs, so 3 OpAmps, 3 transistors and 3 clocks). Any suggestions or ideas why this isn't going well?
    thank you so much for your help
  5. cgama
    Dec 23, 2011
    19
    oh and before, i meant "crude" not "rude".... sorry......
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    For current sources of this kind to be able to give a reasonably large load voltage, the voltage on the emitter resistor should not be too big. Typically, the controlling voltage fed to the amplifier would be attenuated to about half a volt by using a pair of resistors (a potential divider).
    The emitter resistor is then chosen to give the desired current at this voltage. Note that the amplifier used must be of a type able to work with its inputs and output in this low range of voltage: this may be an issue if only a positive supply rail is used.
  7. cgama
    Dec 23, 2011
    19
    thank you so much for all your help. I will try your suggestion
  8. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Hey cgama.
    The way I read your schematic you can adjust the constant current between:
    2.7V / 562 ohms = .005mA
    to
    2.7V / 62 ohms = .045mA
    It depends on what LED you are using if that is a good range.
    Your text-oscilloscope is cool, but it would be more useful if it was more precise; as drawn the two frequencies don't match (at least in the courier new font) so I can't tell where the blip in the collector occurs. However, I would guess it blips are where the 3V rises, that may indicate the LED isn't connected correctly.
    Depending on what is making these 3V pulses you may not need the op amps.
  9. Adjuster
    Dec 26, 2010
    2,147
    300
    It will be very much easier to judge what is going on if you could post a more complete diagram, showing where the "clock" signals come from, and exactly how the LEDs are wired.
    Depending on how much voltage is dropped in the LEDs, the 2.7V or so at the emitters may or may not be excessive.
  10. cgama
    Dec 23, 2011
    19
    thank you for all your help!!
    after much hair pulling i found out the transistor was the other way around.... everything is fine now.
    Once again, thank you very much for your help and time
    tc
  11. Adjuster
    Dec 26, 2010
    2,147
    300
    Thank you very much for getting back to us with the resolution of your problem. It is always good to hear how things come out.
    Actually, this is an excellent example of an issue we often meet when trying to give advice: that is that it is hard to avoid making assumptions which may lead to the real problem not being recognised.
    We must always try to remember the need to check things more than once, and not be afraid to look back again if there seems to be something unexplainable happening (or not happening).
