Hi Guys,
I am finally entering the microcontroller world and will be working on my first project. One of the designs for the projects includes an event X happening when a button is held LOW for 3 seconds. I am not the best programmer but wanted to brainstorm with you guys on how I am going to approach this, and if someone can give me tips, that would be great!.
The microcontroller I will be using is a PIC18F13K50
My basic design is this:
Oscillator will be in circuit and set to 1 MHz with a prescaler of 256:1
The contact switch which will be held for 3 seconds will be connected to Pin 14(RC2) which has an INT2. When the switch is pressed, I will set INT2 to set high when it sees an active low. In turn, INT2 will be an high priority interrupt. From there, the code will go to a Push Button function I will make that will see how long the button is pressed for. In order to achieve this, I will start a timer (Timer0 - 16 bit). The Timer0 will also have an interrupt where it will over flow if button is held for 3 seconds or longer. Now to monitor how long the button is pressed for, I will put in a while loop to monitor the status of RC7 (should be active low) and within the loop, the timer will increment. If it takes the timer0 interrupt to overflow for 3 seconds or longer, than I will do event X. If the timer0 interrupt bit doesn't get set within 3 seconds, than I know the button was pressed for less than 3 seconds, thus the PIC will do nothing.
If you guys can give me tips on the logic of my program, I would greatly appreciate it. In addition, I want to conserve as much power as possible so right when the microprocessor starts, the PIC will be sleeping until INT2 (button press) wakes it up.
Thanks in advance!
Thanks in advance!
