newbie:negative voltage -5v
Discussion in 'The Projects Forum' started by harrys, Apr 22, 2010.
  1. harrys
    Apr 22, 2010
    Hi to all
    I am new to electronics and I am playing with arduino the last few days. I bought a flexiforce sensor but in order for it to work properly tha datasheet says that I need extra circuitry that require -5volts dc to work with MCP6001 opamp.
    Can you propose a circuit or an ic chip on how to get the -5v from tha 5v supply that I can get from arduino?
    thank you
    Harry
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    Also the 7661, MAX660 or MAX860, there are several with similar functions. Some of the Maxim ones are good for 50mA or more.
  4. harrys
    Apr 22, 2010
    thank you for the replies
