hiiiii
i need helpp in this question's
1- what should be the PIV rating of diodes in the circuit ?
2- if one of the diode in the rectifier is opens , what should be the possible output voltage ?
3- if one of the diode in the bridge rectifier shorts what are the possible consequences ?
4- discuss the effect of change in the value of filter capacitor used ?
5- what happens to output voltage of a rectifier if the capacitor becomes very leaky ?
6- if the primary winding of the transformer in the power supply , what will you observe in the rectified output ?
7- the dc output voltage of the filtered rectifier is less thae it should be . what could be the problem ?
plzzzzzz
Thanxxx
plzzzzzz
Thanxxx
