"Newbie needs help" potentiometer as rheostat
Discussion in 'The Projects Forum' started by dvd223, Feb 28, 2009.
  1. dvd223
    Feb 28, 2009
    trying to use on a 12v spotlight to turn down the intensity of the light but i need some kind of heatsink or resistor. I tryed a 50k .5watt pote. by itself and as soon as you turn it down it fry's
    Thanks,David
    (added)dc 12volt Sealed beam 7.36-amp spotlight which produces 200,000 CP
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Is the voltage 12 Volt AC or DC ?
    How many Watts is the spotlight ?
    If it is DC you can use a PWM circuit to dim the spot.
    If it is AC you could use phase cutting.
    Greetings,
    Bertus
  3. dvd223
    Feb 28, 2009
    12 volt (dc voltage) Sealed beam 7.36-amp spotlight which produces 200,000 CP
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Again is it working on AC or DC voltage ?
    This will give info on how to dim the spotlight.
    Greetings,
    Bertus
