OK I replaced the battery and it looks a little better, but I think I have some resistors floating around in the basement somewhere so I'll need another day to get good readings, hopefully.
Sounds like you need another water-level sensor down there, then! .I think I have some resistors floating around in the basement somewhere
Free meter? I was surprised to find them online for about $5. Maybe my wires are corrupted. I paid a lot more for this meter but it seems useless for ohm readings. I'll try to get a new one and take some new readings. I did have some old resistors at home, but the readings were inconsistent. They would all drift upwards slowly, even when I crossed the leads. I'll get back with new readings.That's really poor. Get yourself a free meter from Harbor Freight if/when you can.
I used every range from 200 to 2000 Kohm and still got 1. I'll try your idea about increasing the size of the leads with screws or similar.A "1" indicates the value is off scale. You need to use a higher range. Resistance in liquid depends on many factors including surface area. You might try using a screw or bolt to immerse as this would give a big increase in surface.
I don't know the 'pot' however use the weight of the pot. water out weight goes down.Hi folks This looks like a great forum! I've been reading some background material and trying to see if the answer to my question is in the forum, but I haven't found anything. Let me say briefly that I "used to be" a chemical engineer, so I have some technical background, but it was CHEMICAL. I'm pretty lost when it comes to electronics. I understand basic generation a/c and d/c, circuits in school 30 years ago, etc. What I know about circuit boards would fill 1/2 a paragraph, lol.
I am trying to design what I think is a simple device to sound an audible alarm when boiling water in a pot reaches a low level. I wanted to achieve this without a mechanical float, and I found a circuit that seems to fit the bill, sort of. Below is a copy of the circuit, but the designer at circuitsgallery.com doesn't seem interested in helping people figure out why it doesn't often work. The principle, as I understand it, is that a probe is inserted into the water do the desired depth. This provides a ground and keeps a transistor closed (learned about how transistors work last night, lol). When the water drops below that level, the voltage in the line opens the transistor and causes the alarm.
I have a number questions, but I'd like to ask just a couple to get started (don't want to scare anybody off with 1000 questions about something so simple).
1. Would you consider this generally a good design, and one that could be modified to work for my specific situation. For instance, if I want to use an 18" long stainless rod as the probe, I imagine I might have to change some of the components in the circuit in order to make it work.
2. Can this be made to work using a battery rather than a/c power supply? I would like to make it portable and to use as little battery power as possible.
Hopefully I've described things adequately. Any help, or direction if this is the wrong forum would be greatly appreciated!
Dan
Steam temp will be the same as water temp unless it is superheated, which it isn't just coming out of the pot. I'm looking for a simple way to alarm on low level, and using a probe in water with no moving parts seemed like something to try first.I don't know the 'pot' however use the weight of the pot. water out weight goes down.
measure, at the same time, the 'pot' temperature above 100 deg celcius pot is near to dry or dry. ( steam can go up to 200++ deg Celsius)
picbuster
Boiling water makes a sensor easier, cool water leaves a film that continues a leakage path that your sensor must differentiate from actual immersion. With boiling water, you only have water vapour when the level drops.Hi folks This looks like a great forum! I've been reading some background material and trying to see if the answer to my question is in the forum, but I haven't found anything. Let me say briefly that I "used to be" a chemical engineer, so I have some technical background, but it was CHEMICAL. I'm pretty lost when it comes to electronics. I understand basic generation a/c and d/c, circuits in school 30 years ago, etc. What I know about circuit boards would fill 1/2 a paragraph, lol.
Dan
