Newbie need help working with negative voltages
Discussion in 'The Projects Forum' started by ChrisChemist116, Jun 7, 2009.
  1. ChrisChemist116
    Thread Starter Active Member
    Mar 13, 2009
    78
    these days i have been working in a project that requires +5V and -5V voltages. The IC in question is the intersil ICL7107.
    In the beginning i didn't know how to plug the wires to each battery so i could drive out the desired voltage. On my first two attempts, i accidentally blown two tantalum capacitors (2.2uF) on the LM7905 input. After reviewing my books, i came to the conclusion that i have been working with reverse polarity and i also accidentally misunderstood the pinout as my decision was to work with LM7805 and LM7905 and these two have different pinouts.
    Okay, the question is this:
    Is my schematic correct?. (PDF attached). Is that the correct way to drive out +5V and -5V from two 9V batteries.
    Help will be graciously welcome
    pd. Sorry for the graphics quality i didn't had time to make the schematic on the computer.
  2. haran
    Apr 6, 2008
    42
    i tried out your circuit using multisim 10. but the negatif terminal doesnt seems to be given off -5 volts.
    do go to this website to check out their idea on how to generate a -5 volt
    http://www.elecfree.com/electronic/generating-5-volts-from-a-9-volt-battery-with-ic-555/
  3. eblc1388
    Nov 28, 2008
    1,542
    102
    It doesn't need a circuit simulation to tell if the circuit is connected correctly. In this case, the simulation result is totally wrong. :mad:
    One additional point regarding tantalum capacitor.
    These capacitors are marked with a dot or a dark/black line near one pin. This is the positive +ve connection. Countless people have applied the marking convention of normal electrolytic capacitor and blown up their tantalum caps.
    Yes. Do yourself a favor. Always put in the polarity marking on a cap so it is easy to see if mistake is made when checking the circuit later.
  4. haran
    Apr 6, 2008
    42
    as i said b4 through the simulation i got the positive 5v...but unable to generate the -5 volts...and i do noe how to read schematics tq..if u have multisim 10 i willl gladly send the simulation file
