hello,
link to datasheet for the lm3915
I know this is supposed to be child's play. Every thread i've read about the lm3915 people just say: "read the datasheet".
But my knowledge isn't good enough yet, i can't understand most of the datasheet.
- first question:
They say the Vled (which is the positive for the leds) must be less than the supply voltage (the positive for the lm3915).
When i build the circuit, should i use a voltage divider to reduce the voltage of the LED's positive (Vled)?
- second question:
Audio guru (a user of these forums who seem to know EVERYTHING!!) always suggest to add a resistor to limit the current for 15mA+ circuits.
- where should i put this resistor? In series with the Vled?
- How should i choose it's value?
example
- my plan is to have 2 leds in series @20mA per output, should i add a resistor per output to help dissipate the heat? if yes how should i choose the value of the resistor?
12V (input) - (3.2V + 3.2V) = 5.6V to kill with the resistor?
5.6V/0.02MA = 280 Ω?
- Third question:
I want to be able to adjust the thing so that the whole tower will light up even if the volume isn't insanely high. (precision reading isn't a concern, just want to make it pretty
My idea is to reduce the range of the lm3915 to 6V, (most vu meter are setup to 10V range), but add a voltage divider to the signal with a potentiometer so that if the volume do get very high, i can reduce the voltage of the signal and still have the vue meter light up from the bottom to the top. (instead of having all of the LED lit permanently without moving when the sound gets too high).
Is this a good idea?
is this whats happening here? (this is not my circuit, just a circuit i've found searching the web)
- Bonus question:
What software is used here?
Thank you so much if you take the time to help me out even just a bit.
-p
- first question:
- second question:
example
- Third question:
- Bonus question:
-p
