Newbie, I need help with circuit design
Discussion in 'General Electronics Chat' started by blame, Jul 5, 2007.
  1. blame
    Jul 5, 2007
    hello everybody
    here is what i want to do
    i would like to have a variable temp wood burner the type you change the whole pen not just the tip
    what would be the best circuit to use for varing the temp at the tip of the pen ? i would assume that you would use a pot to change the wattage from the control box to the pen
    i would like a temp range 0-2000 degs what would i have to use to obtain that? the other things i need to consider is shielding my hands from the heat coming from the tip, what would be the best material to use for the hand piece? i've seen aluimum, wood and composits used in make the store bought models
    i'm just starting my research for this project , before you say just buy one ,no thats not what i want to do not because of the cost most retail from 75 to 1000 bucks so i could find one that would be a deal thats not what i want
    i want to build my own just dont know where to source everything
    thanks for the help
    blame
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You would use a variac to change the temperature. 2000 deg. is a bit more than a metal tip can handle. That's more like a flame temperature.
    A wood-burning iron, like a soldering iron, is pretty well perfected. hardly anybody makes his own soldering iron from scratch, as it could never be as compact as a commercial unit. Good luck on the project.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Are we talking celsius or fahrenheit? Metal starts glowing around 1000F.
    An ordinary triac light dimmer will allow control of a low-cost wood-burning pencil. You can put the dimmer and an outlet both into a "4-square" box, run a cord out one of the knockouts via a clamp connector, and finish with a night-light to indicate "power on." I have the same arrangement for my soldering iron.
  4. recca02
    Apr 2, 2007
    1,211
    maybe u wud like to borrow some idea from the ignitors used in boilers for oil and pulverised fuel firing.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You can make a cheap one variable with a light dimmer rated for the wattage.
    I can't seem to find a link to the ones meant for existing floor lamps. They have a cord, nice outlet and knob all ready to use.
    Ones you'd have to wire up are here but go to incredible wattages.
    http://www.electronicplus.com/content/ProductPage.asp?maincat=E&subcat=EDI
    If you must build one here is one similar to the above at 1200Watts.
    There are lethal voltages, you'll go blind, your momma will cry if you make a mistake.
    http://home.cogeco.ca/~rpaisley4/x1200WControl.html
