I bought a alarm clock kit for my project. I wanted to connect this kit with another circuit that I made which contained several LEDs which will light up gradually. I was thinking of powering the LED circuit from the kit's output; buzzer.
However the issue is, When I did connect the LED circuit to the kit the LEDs started flashing due to the pulsing power output.
Is there a way I can possibly change this pulsing output to constant and stop the LEDs from flashing?
I know for sure that the LEDs i used aren't flashing LEDs as i have connected it separately to a PSU and the leds didnt flash.
I don't really want to change the kit's function as it physically cannot be changed.
I tried making a bridge rectifier circuit, but it didnt work as the power going in the kit was DC.
Could you please suggest ways i could solve this problem?
Click this link to see the details of the alarm clock kit that i used
Thank you
Thank you
