Hi all
Yet another 555 relay question, though I hope this one is different enough to make a worthwhile post. Disclaimer: I am an electronics nuff-nuff, I own a soldering iron and can make an LED flasher or a siren for my kids bike but that is about it so please use small words if you reply.
The ultimate aim is to close a solenoid on an air compressor valve, 12vDC at about 600mA. The solenoid only needs to fire for about 500ms, just enough to shoot a small burst of air through the valve then shut off again until I press a button once more.
My intentions are to:
I have spent the last three days reading posts here and elsewhere and I think I understand what I am reading but I have also read many times about the perils of inductive loads on 555 chips.
Any information or advice most appreciated particularly on the "downstream" parts of the circuit as to the relay and solenoid and how to protect the 555 circuit from them.
Thanks for reading.
- Use a 555 wired as monostable to give me a pulse I need. I think I am OK on this part using 1.1xRxC to give me the right pulse time and feeding this circuit from a 9v battery. Input would be from a SPST micro switch.
- Use the pulse to energize the relay coil. Am I right that I need to pick a relay that has a high enough coil impedance to not exceed 200mA for the 555 ?
- Provide a separate power feed on the relay contacts to close my solenoid.
Thanks for reading.
