newb question on KCL algebra
Discussion in 'Math' started by naitek, May 18, 2014.
  1. naitek
    May 31, 2008
    15
    Hello; I am trying to find how to go about solving KCL, KVL not the equations, but the math.
    The first equation results from KCL applied at node 1, the second equation results from KCL applied at node 3 and the third equation results from KCL applied at node 4. Collecting terms this becomes:
    i understand getting the equations, i just dont know how to go about using Gaussian elimination or some other way mathematically to ge tmy answer. thanks
  2. shteii01
    Feb 19, 2010
    3,507
    512
    You have 3 unknown (V1, V3, V4) and three equations. Look up how to solve System of Linear Equations.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Since you mentioned Gaussian elimination, go Google Gaussian elimination and read up on it. Then come back and make you best attempt to apply it to the system of equations above and we can help you find and fix any mistakes you make.
  4. Fibonacci
    May 23, 2014
    25
    5
    Simplifying, you can express in matricial form the equations:
    (1/9)V1-(1/30)V3 = -55/9 ... I
    -(1/30)V1+(7/75)V3-(3/50)V4 = 107/15 ... II
    -(3/50)V3+(19/150)V4 = -19/5 ... III
    [1/9, -1/30, 0
    -(1/30),(7/75),-(3/50)
    0,-(3/50),(19/150)], this is known like coefficient matrix, "A".
    Also we have the variable vector x= [V1;V3;V4] and the results vector
    b=[-55/9;107/15;-19/5].
    You can find the answers for the vector x solving the following matrix equation: x =A^-1*b, where A^-1 is the inverse matrix. It is easy, only you need to have a computer that performs the operations, for example, the TI-89 calculator, MATLAB, etc.
