Newb question on capacitor
Discussion in 'General Electronics Chat' started by Graygem, Jan 27, 2012.
  1. Graygem
    Feb 4, 2011
    Newb question. On the non inverting amp below, what is the capacitor for? I see the capacitor on some circuits but not on others. Does it make a difference if the circuit is single supply or dual supply?
    Thanks.
  2. mik3
    Feb 4, 2008
    4,846
    63
    For DC input signals the output follows the input.
    For AC input signals with frequencies greater than 0.333Hz, the output is 100 times greater than the input.
  3. Graygem
    Feb 4, 2011
    That makes sense, thank you. So R2 + R1 and C create a high pass filter. Now, I have also seen a small cap, say 22pF, in parallel with the R2 resistor. What does that cap do?
  4. mik3
    Feb 4, 2008
    4,846
    63
    It decreases the AC gain at high frequencies.
  5. Graygem
    Feb 4, 2011
    Thank you. I appreciate your time.
  6. crutschow
    Mar 14, 2008
    13,508
    3,385
    Usually that capacitor is to allow offsetting the input DC voltage (typically by 1/2 the supply voltage) to allow an op amp that normally requires dual supply voltages to operate from a single supply. It makes the DC gain equal to +1 but the AC gain is determined by the ratio of the two resistors.
