I'm comfortable with Ohm's law and analysing series/parallel circuits with resistors, but I'm struggling when it comes to analysing some simple circuits with transistors.
The attached circuit is from an entry level electronics book, but I'm not sure what the purpose of the 100k and 47k resistors is. It's a continuity tester, so the probes may be shorted (no resistance). The idea is that if current flows between the emitter and the base, the LED will light up. So, what's the purpose of the 100k resistor? If it was omitted, current would still flow through the base and turn on the LED wouldn't it?
And is the purpose of the 47k resistor to divide the voltage between the emitter and ground like in the discussion about the common collector amplifier in vol. III of All About Circuits? Ie, the voltage drop between E and B is 0.7 volts, and the drop over the 47k resistor is therefore 5.3V?? And the reason for that would be to prevent the transistor getting the whole current and burning out? But this is a common emitter arrangement isn't it, not a common collector?
What am I missing?
Thanks.
What am I missing?
Thanks.
