New with High Side P Channel- Take a look?
Discussion in 'The Projects Forum' started by ChrisHelvey, Aug 6, 2013.
  1. ChrisHelvey
    Thread Starter Active Member
    May 22, 2004
    45
    Let me pre-empt this with saying I am a self-taught hack with a very old (and nearly useless today) computer science degree. I have never designed with a P Channel Transistor before. My project is a PIC based 60V battery charger (from 12V Solar) for a 48V LiFePO4 battery pack. (Please don't question about Li battery charging - THAT part I am clear about and a BMS is in place.)
    So, in order to take readings of the battery pack voltage on a Pic A/D pin, I needed to disconnect the 60V supply. Thus, the use of a P channel MosFET.
    Here is that part of the circuit.
    Anything majorly wrong?
    Thanks everyone.
  2. joeyd999
    Jun 6, 2011
    2,756
    2,916
    What pmosfet are you going to use?
    Edit: the reason I ask is you have to watch out for Vgs exceeding the max specification. If so, you'll need a voltage divider on the gate (rather than pulling it all the way down to 0V).
  3. crutschow
    Mar 14, 2008
    13,469
    3,356
    What is the PIC PWM circuit that can switch 60V?
    As joeyd999 stated you need to limit the Vgs voltage (20V is a typical MOSFET maximum, so you should limit it to 10-15V)
  4. ChrisHelvey
    May 22, 2004
    45
    I haven't chosen one yet. Recommendations are welcome. :) Price isn't really a concern because it's just a personal project and these parts are pretty cheap compared to a more difficult design.
  5. ChrisHelvey
    May 22, 2004
    45
    The more I look, the more I think using an N channel to do the logic switching makes sense. Like this:
    Make sense?
  6. joeyd999
    Jun 6, 2011
    2,756
    2,916
    And that is exactly the way I would do it... ;)
  7. ChrisHelvey
    May 22, 2004
    45
    Oh good. I'm on the right track! Like I said, I'm a hack, so I only partly know what I'm doing, but not completely ignorant.
    Thanks a lot.
    Chris
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    With the zener added you don't necessarily need the gate-source resistor.
  9. ChrisHelvey
    May 22, 2004
    45
    So I just need to choose resistors for the voltage divider that will be the correct ratio and end up under the current limits of the PIC pin's sink, yes?
  10. ChrisHelvey
    May 22, 2004
    45
    Thanks. That makes sense, since the divider on the high side should limit current. Hey, maybe I'm getting the hang of this thing, huh?
  11. ChrisHelvey
    May 22, 2004
    45
    So, I was thinking of using an IRF9540N (datasheet here: http://www.taydaelectronics.com/datasheets/A-083.pdf) for the P channel.
    Max Vgs is 20V. Does this voltage affect how much it is "on," as in its saturation? In other words, as a switch, do I need to make that voltage as high as possible without going over, or is it fully on when it's at 10 or 12V or so? I've never been quite clear on that.
  12. joeyd999
    Jun 6, 2011
    2,756
    2,916
    It doesn't hurt. And it adds just a bit of protection in case of either the network becoming disconnected or an over-voltage situation.
    Edit: More clear: either use the resistor or zener or both. If you use both, it just adds a little protection if either fails or becomes disconnected.
  13. ChrisHelvey
    May 22, 2004
    45
    Does it play in to the voltage divider equation, being on the other side?
    And thanks for your responses. I really appreciate the help.
    Chris
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Without the G-S resistor, the PMOS will take forever to turn off once the zener ceases conducting. You definitely need the resistor.
    With TTL input, you will need a logic level NMOS. An NPN is a good alternative.
  15. shortbus
    Sep 30, 2009
    4,086
    1,664
    I must be missing something here, usually am. Why not just put the load before the drain of a Nmos and be done with it? One gate resistor and one logic level Nmos is a lot simpler.
  16. joeyd999
    Jun 6, 2011
    2,756
    2,916
    Your are correct. Not putting much thought in my answers....busy with a rather intense math problem at the moment. Perhaps I should shut up till I'm done. :p
  17. crutschow
    Mar 14, 2008
    13,469
    3,356
    You are quit correct. Didn't think my answer through. :p
  18. crutschow
    Mar 14, 2008
    13,469
    3,356
    The datasheet will tell you the Vgs required for full turn-on. That voltage is shown in the specification row that lists the ON resistance. Any voltage higher than that will have little effect on the ON resistance.
  19. ChrisHelvey
    May 22, 2004
    45
    OK, so the resistor will stay. Does it play into the voltage divider equation?
    I have some logic level N Channel Mosfet transistors here so I will use one of those to operate the P-Channel.
    The datasheet says "2-4V Gate Threshold Voltage." So, it doesn't need much to saturate.
    Thanks everyone.
  20. ChrisHelvey
    May 22, 2004
    45
    I don't really understand what you mean. I couldn't figure out how a 5V logic signal could turn it on in the position it is located.
