new to this...please help
mcgyvr
Joined Oct 15, 2009
5,394
The attachment point is on the control board not the motor.
More than likely needing (expecting) a momentary signal.
Or are you taking it all apart and not using it on a garage door opener.
If so specs of toggle switch will be needed too..
glynn
Joined Jan 30, 2015
9
My plan is to use it on a bead roller so I want to bypass the remote sensor and I have a 6 pin dpdt toggle
Reloadron
Joined Jan 15, 2015
7,517
Looking at the motor image and the large cap this is what I see:
The drawing is rough but I believe you have an AC motor that uses a cap to reverse direction. There is what looks to be a big can AC cap in the images. The motor tag shows a cap and that is a common AC motor color scheme for motors of this type. Since you only want the motor I would wire it as shown. I based the line, neutral and ground color scheme on common US AC 120 VAC mains. I am also not sure about forum TOS as we are dealing with AC mains power here. Anyway, this is my guess.
Ron
