New to Solar Cells
Discussion in 'The Projects Forum' started by s33d, Feb 16, 2012.
  1. s33d
    Feb 14, 2012
    I'm working on a model kit and embedded an LED inside it for cool glowing effects. I usually plug batteries in, but decided it would be cool to use a solar panel instead, so I bought 2 of the really cheap solar LED flashlights.
    Got it open a-ok, the circuit is simple. Diode to prevent back current, 3 LEDs in series, and a momentary switch.
    The only problem was that I couldn't find a datasheet for the cell (a QFsolar 3722-9L) so I grabbed a multimeter to take readings so I didn't fry anything. I get a max of around 7V, but the current seems odd to me. I can only seem to get .1mA flowing out. I've never done anything with solar cells before, is this typical?
  2. BSomer
    Member
    Dec 28, 2011
    433
    106
    Could be.
    Short circuit current ratings of individual cells usually don't add up to much. Though 100uA is kind of small. Did you check the current in bright day light or under some other source of light?
  3. BSomer
    Member
    Dec 28, 2011
    433
    106
  4. s33d
    Feb 14, 2012
    Yep, under the same conditions that give me my ~7V. It bounces from 0μA to 100μA depending on what I do with the light.
    It could just be that this is a cheap panel and was designed that way, but with no datasheets there's no way for me to know. I wanted to remove the need for a battery completely, but with 100μA, that's not going to be possible.
  5. s33d
    Feb 14, 2012
  6. s33d
    Feb 14, 2012
    bump for great justice. nobody have anything to say on this?
