New To Projects. Need some help
Discussion in 'The Projects Forum' started by Mwhite0788, Feb 22, 2015.
  1. Mwhite0788
    Feb 22, 2015
    I am working on rewiring a Bingo Flash Board. It has 80 Lights 5 which stay on all the time and 75 which i will have hooked to switches. The way that the Board Worked Previously is it had a Power Transformer that Linked to a 5V Bridge Rectifier. What i am going to do is direcly connect each switch to its corresponding bulb. What i need to figure out woud be the best way to ensure that I am getting enough power to all the bulbs to light them.
    Should use multiple Bridge Rectifiers In Line with the Transformer instead of trying to Get all the power from one?
    I can supply more information as required. Just starting off and am trying to figure out where to go. I already have the switches and the Lamp Holders, as they came from the original Bingo Flashboard.
    Thanks,
    M.
  2. Bernard
    Aug 7, 2008
    4,248
    424
    We need specs on bulbs & transformer.
  3. Dodgydave
    Jun 22, 2012
    5,172
    778
    You need to know the total current of all the bulbs when lit, then choose a bridge rectifier to fulfil your need as one will do.
  4. Mwhite0788
    Feb 22, 2015
    The Bridge Rectifier is an exact replacment of the original Specified.
    on And According to the Manual Trouble Shooting I should get 28 Volts AC on the AC side of the Bridge Rectifier, which is also what i am getting out of the Transformer.
    And i was wrong its not a 5V bridge rectifier it is 28 VDC output on the Bridge Rectifier.
    Like i said I understand how power flows and such, but I am new to using Bridge Rectifiers, and How it works with Multiple Bulbs being lit at once..
    Thanks,
  5. Dodgydave
    Jun 22, 2012
    5,172
    778
    your bulbs will work on AC, so why do yo need a bridge rectifier??
  6. #12
    Nov 30, 2010
    16,705
    7,358
    The rectifier doesn't care, as long as you don't exceed its current rating. That's why we need to know about the bulbs to calculate the current.
    and yes, why do you even need a rectifier?
  7. Mwhite0788
    Feb 22, 2015
    When there was a Circut Board (which is what failed and i am trying to get rid of) it required a Bridge Rectifier, So I just assumed it was necessary for either the switch or the bulb.
    So how do I get the Current Requirements of the Bulbs?
    Thanks,
  8. #12
    Nov 30, 2010
    16,705
    7,358
    Read the label.
    Google the part number.
  9. MaxHeadRoom
    Jul 18, 2013
    10,870
    2,528
    Lamps, Voltage? Wattage?
    Max.
  10. Mwhite0788
    Feb 22, 2015
  11. #12
    Nov 30, 2010
    16,705
    7,358
    If you're going to change volts to watts, at least spell watt correctly.
  12. MaxHeadRoom
    Jul 18, 2013
    10,870
    2,528
  13. #12
    Nov 30, 2010
    16,705
    7,358
    You need 8 amps of 28 volts. One way is to use your 20 volt transformer rated at least 260 VA with a rectifier and about 18,000 microfarads to smooth the power out, or you can get a 28 volt transformer rated at 8 amps.
  14. izon
    Member
    Mar 17, 2013
    163
    5
    Hi "Mwhite"
    I've worked a few times on a "Bingo Board" at a local American Legion club. Usually minor things and the various lights, which indicate the number last called, are
    triggered on via a circuit board. They don't use any mechanical switch for that and I'm not that well versed in the digital side of how much of this is accomplished.
    Not sure how you are going to be operating this... someone manually flips a switch to light the appropriate number, I'm guessing... Don't know if I can be of any
    help but happy to try.
  15. KJ6EAD
    Apr 30, 2011
    1,426
    364
    I'm guessing that the original circuit board simply contained a latch and driver for each bulb to facilitate use of momentary switches and a global reset.
    Is there any possibility of repairing or replacing the board instead of changing to a cumbersome switch per bulb arrangement?
