But can that reference be used as an ADC reference? For some time ago I looked at at a new PIC with internal reference. It turned out that the reference could be internally connected to a ADC channel and read. But not used as a reference for the ADC. Have they changed this in this IC? It is hard to keep track on every new PIC. So that is why I am askingMy mistake!
Rif@@ I thought you were using the 40-pin PIC that comes with the EasyPIC7 dev board. That one has the internal ADC reference.
I just had to go and boot up my other computer and check the datasheet.But can that reference be used as an ADC reference? For some time ago I looked at at a new PIC with internal reference. It turned out that the reference could be internally connected to a ADC channel and read. But not used as a reference for the ADC. Have they changed this in this IC? It is hard to keep track on every new PIC. So that is why I am asking
The 16F88 only has a comparator Vref module, and the datasheet says it is derived from Vdd so will not be more accurate than Vdd.Rif@@ said:Tell me please what is better, the internal reference or the Vdd ?
if (PORTA.b0==0)
code1
else
code2
while ( PORTA.b0==0)
code1
code2
Thread starter | Similar threads | Forum | Replies | Date |
S | Mikroe C V X 16 revisited | Microcontrollers | 0 | |
Issues between the Mikroe USB SPI click (MCP2210) and the AD9851 | Analog & Mixed-Signal Design | 4 |
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
