First off, hello. I'm the latest new guy. I know enough about electronics to only be dangerous. I worked on electronic warfare systems in the USAF for about 20 years but to be honest, the job mainly consisted of swaptronics and there were limiting rules about what maintenance could be performed on these systems. Component replacement was not permitted. Since I retired however, I've successfully built about a dozen vacume tube guitar amplifiers from scratch with point to point wiring and constructed terminal lug circuit boards.
I've been playing around with LEDs. I'm an avid motorcycle rider and am always looking into custom lighting including off road auxiliary lighting. The use of very bright LEDs is still quite new and the cost of the best packaged manufactured components is high. Just like the early CFLs, these new LED lights are very expensive and will remain so until there is more competition in the market. LEDs are perfect for off-road motorcycles due to the very limited available current from the alternator.
Car and motorcycle voltage is 12 to 15VDC so when using LED components, I need to reduce the voltage most of the time unless I configure the LEDs into some sort of multiple LED, in series, idea. The bad thing here is that I'm restricted to using multiple LEDs and if a single component dies, everything dies from either an open circuit or a totally blown circuit if the death of a single component creates a situation of a short -- the over current wipes out everything. That is really bad news if the LED light is the only illumination you have on a motorcycle.
Some LED lighting is becoming affordable with many inexpensive hand held flashlights manufactured in China. My son just purchased a 1000 lumen flashlight for less than $20 on ebay and its performance is awesome considering that it operates on three C-cell batteries. It has a single LED chip installed in a quite decent projector style mirror and lens assembly. The width of the beam is fully adjustable from a wide angle to a very in-focus square of about a 5 degree arc. This flashlight is all aluminum and waterproof. I could easily hack this thing apart and in a very tidy fashion, mount it on a motorcycle.
Here is the question. Is it reasonable to use just a simple power resistor to control the current when the power source is a fairly unfiltered and roughly regulated 12 to 15 VDC output of an alternator output? Should I employ filter caps? Or, is the voltage source probably so uncontrolled that I need to get into an actual complicated semiconductor voltage controller so the longevity of my LEDs is not compromised? "Simple Is Better", is a rule that I'd like to follow. On the other hand, I'm probably wasting my limited available current in a power resistor which defeats the use of an LED. Is there a simple solution of an available voltage control device or circuit? Thoughts???
By the way, I am now a professional luthier and have been so for the last 15 years. If anyone needs assistance with guitar electronics or anything related to stringed instruments, I'd be happy to assist.
